a few engine management questions
Okay so after an emo fit in the main forum, I've finally got the car running half way well, the turbos aren't spooling but at least it's progress. Anyway I'm concerned that my turbos are bad and if that's the case I'm just going to get an HX35 or an HX40 and go single. Now my question is, if I do this could I use the stock ecu or would I would risk damaging my engine? I know alot of subaru guys that just use Fuel Cut Defender and call it a day on relatively low boost. I figured I'll half to upgrade from my stock fuel pump but that's about all I know. Thanks for the help
You will be fine with the stock ecu, upgrad the fuel pump, injectors, and safc . I would not worry about Speed cut defender till you get it running properly.
You can do it !
You can do it !
