I have a check engine light which is pointing to a carboned up EGR valve. Does anyone have any tricks for getting the EGR pipe off? The top is undone, but it seems that the bottom of the pipe must also be loosened to get the EGR valve off the car. Any tricks in doing this? The car is a '95 sc300.
i dont think the pipe has to come off to pull the valve its just unbolt the valve from the pipe and the 2 bolts that hold the valve to the intake manifold.. i think..
Thank you for the replies. My issue is getting to those two 12 mm bolts on the bottom side of the EGR pipe. I can not see a way to get to them without removing the intake. I think if the intake manifold comes off, the EGR valve should come with it.
