I did the impossible...now need advice
Here's the deal.
You blew up a 2jz, congrats by the way.
Since it's blown, and I'm a GTE advocate personally, put a good un-ground crank back in it, stock rods, some 8.5:1 pistons, and do the NA-T.
The experience, and knowledge of building an engine from the ground up will be useful in any car.
Plus, if anything ever goes wrong you know just how to get to the problem with 100% confidence.
I somehow vote, Mild Built NA-T, who knew!?
So is it possible to not machine the block in there now with a fresh set of bearings/rods?
With a spun bearing.
If you want it back to stock, just buy a used engine.
If you want it to have power. Buy a used turbo engine.
If you want lots of power.
Bore yours 20 over. Buy new crank uncut, and buy new rods. Aft mkt turbo pistons. Cause your new to it, get a decently stock compression piston. 8-8.5:1.
SCguy58
Performance & Maintenance
33
05-14-06 06:39 PM
ummagawd
12-17-05 10:32 AM
