How Much Power
Old 04-03-12, 06:24 AM
super300
super300's Avatar
Default How Much Power
How much power could I expect my SC300 NA-T to make at the wheels? It's a 5 speed (upgraded clutch) with a stock GE, 67mm turbo, TT head gasket, APR head studs, 550cc injectors, and a MAPECU1. Everything else is stock. The car will be on 93 octane pump gas.
Old 04-03-12, 09:10 AM
Bigzavs
Bigzavs's Avatar
how much boost do you plan to run?
Old 04-03-12, 09:12 AM
super300
super300's Avatar
As much as I can possibly run safely. I don't know whatmy limit is with stock timing and fuel besides the 550s.
Old 04-03-12, 09:29 AM
Bigzavs
Bigzavs's Avatar
with a similar setup, except for 63mm and a stock fuel pump i did 366whp at 12psi. the stock pump is really going to hold you back
Old 04-03-12, 09:33 AM
super300
super300's Avatar
I thought the timing was going to give me a problem, not the fuel pump. Is it possible for me to get into the 400s with the stock pump/timing?
Old 04-03-12, 09:34 AM
Bigzavs
Bigzavs's Avatar
its most likely possible, but the pump on mine would drop pressure past 340whp
Old 04-03-12, 09:46 AM
super300
super300's Avatar
Alright, thanks. Anyone else have any experience?
Old 04-03-12, 09:57 AM
broda805
broda805's Avatar
just swap in a walbro it only takes about an hour leisurely and they are about 100$ pretty cheap and easy and then you dont have to worry about it
Old 04-03-12, 12:04 PM
SFrymyah
SFrymyah's Avatar
Getting tuned with no pump on that turbo is a waste of money and dyno time. You'll spend less than $100 on a 255 or spend a liiiiittle more and get the 400 lph. That turbo won't even come alive until you give it enough fuel to really get it breathing.
Old 04-03-12, 02:09 PM
lookEVO
lookEVO's Avatar
i still have stock fuel in mine at 350 hp and im pulling fuel in boost... i think you all are confused. He has bigger injectors and lower compression.
Old 04-03-12, 02:56 PM
Bigzavs
Bigzavs's Avatar
your pump doesnt have to work as hard to keep pressure to your stock injectors, with larger injectors, the pump will begin to lose pressure above where your power level is. I had a pressure gauge on my fuel rail, and could watch the pressure start to drop once i got over 6,000 rpms
Old 04-03-12, 03:03 PM
lookEVO
lookEVO's Avatar
Im just saying ive tuned cars with the stock fuel pump and bigger injectors. Hes not shooting that high. Doesnt mean i dont think he COULD use one, just saying it doesnt have to be the crux.
Old 04-03-12, 04:05 PM
super300
super300's Avatar
Can anyone recommend me a pump? I'll most likely be buying from MVPMotorsports.
Is there anything I should know or do when changing the pump or is it literally just a swap from one to the other, plugnplay?
And will I be experiencing any trouble with my stock timing, since I can't retard it with the MAPECU?
Old 04-04-12, 05:14 AM
super300
super300's Avatar
Is the Walbro 400lph from MVP any good? It's the first one on this page:
http://www.mvpmotorsports.com/Templa...947&SearchYN=N
Old 04-04-12, 06:33 AM
chizz95
chizz95's Avatar
Id say your setup 17psi max 67mm turbo...430rwhp maybe..deff do a pump upgrade I just did a walbro 255 two days ago takes like 30-40 mins..
Quick Reply: How Much Power
