fail smog again? -_________-
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I don't get why my smog got fail again? Since my car already fixed when i took my car to the shop fixed in last month as tune up,timing belt and water pump also more too.. so after few days i took my car to the smog test and it got fail since my car running like good champ and smooth?? what it cause?![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Seriously, I really hate SMOG stuff.. -____________-
Anyone can help me? but If i haven't change oil in a while that will cause affect due fail HC?
I already replaced new cat in last year.
![](http://img189.imageshack.us/img189/5517/imag0498y.jpg)
HELP ME PLEASE! -__________________________________-
cleansc4- you can dull down your gas with aclocal your car will run like **** but show show good resolts check your cats and then try octain booster. i also have herd that you can use methanal? dont take my word for it (and on the aclocal thing google the amout of alchacal to gas ratio)
-GOOD LUCK
-GOOD LUCK
Yeah, all the expensive maintenance helps.
You should check these things off the list:
New spark plugs and wires
New distributor blade (if applicable)
All new O2 sensors (ALL of them)
New PCV valve
New EGR valve (if needed)
Ignition timing set correctly (especially important on a 2JZ-GE)
New main catalytic convertor(s) (Look up Lexus OEM and Catco direct fit and buy whatever is the cheapest. OEM is the best but often isn't worth the money).
New secondary cat if necessary (again, Lexus or Catco direct fit and buy the cheapest)
Any combination of the above should do it. From the look of your numbers I'd say it's the cats but do everything else first before going to that trouble and expense. Good luck.
And yes, CA smog sucks. Not because we need a properly functioning emissions system but because of the visual inspection, which is absolutely useless and pointless other than to make more money, waste time and discourage engine modification that could give nice older cars new life.
New PCV valve
