Gaskets and RTV and FIPG
I own 92 ls400 with 239,xxx and same year sc300 with 189,xxx. I have done the trans pan and filter on my ls400. My question is what is everyone using when they seal up they're pans? , whether it be your transmission pan or oil pan? I'm coming across a lot of rtv gasket types. But when I Put on my tranny pan for the LS I used a gasket. My local auto parts store carry the gaskets that I need, but is there a difference to using rtv instead of an actual gasket? Im assuming most oem applications call for rtv... I just don't like the idea of using rtv because I had to clean it all off the tranny pan for it to mount flush. Is rtv good or bad? Can a gasket be used instead of rtv? Example would be the sc300 throttle body. I haven't taken mine off but ive read there's a metal gasket stamped into it that is reusable?
Thanks in advance
Thanks in advance
simply put, if it has a gasket already, replace it with a gasket of similar structure and design. Don't attempt to substitute a solid gasket with RTV or FIPG. Same applies the other way around, don't sub a solid gasket for RTV/FIPG. It has to do with the mating surfaces between metals and their application.
