yellow oil light help
Old 04-13-12, 06:59 PM
dawizone
dawizone's Avatar
Default yellow oil light help
Which sensor controls the yellow oil light? Is it the oil pressure sensor under the intake or is it the sensor on the oil pan next to the dipstick? Or am I way off on either?
Old 04-13-12, 07:36 PM
g4ebguy90
g4ebguy90's Avatar
Yellow oil light??? isn't it red?
Old 04-13-12, 08:38 PM
GS4_Fiend
GS4_Fiend's Avatar
Did you checked your oil level?
Old 04-14-12, 02:42 AM
dawizone
dawizone's Avatar
@ GS4_Fiend oil level checked before and after every drive... @g4ebguy90 believe there is both yellow and red.... red being much more dangerous
Old 04-14-12, 05:05 AM
99SC42
99SC42's Avatar
Oil level is the one in the oil pan with wires coming off from it, tells if you oil level is low. Yellow
Oil pressuse is the red one (danger de mort) it's located behind the A/C compressor , it screws right into the block.
Old 04-14-12, 07:14 AM
dawizone
dawizone's Avatar
Thanks exactly what i thought just wanted to confirm
Old 04-14-12, 10:25 AM
dawizone
dawizone's Avatar
hey Omar do you happen to have the part number for the oil pan sensor? is that the $300 one?
Old 04-14-12, 09:19 PM
g4ebguy90
g4ebguy90's Avatar
Its just a sensor, try autozone man. Not everything has to be LEXUS dealer only. Starting to realize that now... If your oil pressure light comes on, your screwed anyways. Oil level, your not checking your engines blood enough.
Old 04-15-12, 02:17 AM
dawizone
dawizone's Avatar
^^^ yea man by no means am i an expert but i have been doing it a little while so I know that.... but look up oil level sensor at Oreillys autozone napa etc... and you will see that there is no cheap option.... if you can find one please let me know!!
LEXBOGGY
15
12-20-16 09:04 PM
2jznosht
20
05-05-13 06:08 AM
roy1928
07-21-08 04:48 PM
MLDNYC
03-21-06 07:02 PM
VSsc400
SC- 1st Gen (1992-2000)
12-03-02 01:13 AM
Quick Reply: yellow oil light help
