My car idles SUPER low
first i thought it was kind of cool because it idles super quietly. i personally like it but i heard this is a bad thing. it idles at around 200 RPM. any ideas??
ill show this to my brother because... i have no clue what any of this is. i like mechanics, just havent learned to much technical stuff. i know its supposed to be at a healthy 800 RPM's
I had a low idle for the longest time, couldnt figure out what it was for the life of me. I'm pretty sure I tried everything in the book.
Turns out my rpm gauge was off, showed 100-200 rpm at idle, when a OBD scanner showed 700 on its reading. Took me forever to figure that out; so that may be an easy answer for you.
This didnt work for me (obviously because my idle was actually ok), but when I tightened it, it threw all my gears off..
If the idle was actually 200, it would run rough and probably cut off on you. You might have the same issue that scEnforcer has described. Have you run a code scanner or done an OBD1 code test just to see if your ECU is hiding any codes? It might be a good time to check it out.
i need to run the diagnostics machine asap lol
