350Z trans adapter?
Old 02-10-13 | 04:36 PM
  #166
afro88's Avatar
afro88
There was talk about the starter teeth not engaging the flex plate due to the distance added by the flywheel adapter. There's a ton of speculation about this whole setup though so I'm not surprised if that's not the case.
Old 02-10-13 | 06:30 PM
  #167
Halon's Avatar
Halon
The flywheel adapter is for the flywheel. The flexplate stays in the stock location as far as I know.
Old 02-10-13 | 06:45 PM
  #168
airfed's Avatar
airfed
Who has a setup that spaces the flex plate away from the crankshaft. For obvious reasons that shouldn't even be tried lol.
Old 02-11-13 | 10:48 AM
  #169
airfed's Avatar
airfed
Started my own swap thread so I dont junk up the sc300 thread with IS info haha.
https://www.clublexus.com/forums/is-...sion-swap.html
Old 02-12-13 | 10:17 PM
  #170
2jzcoupe's Avatar
2jzcoupe
I just picked up my brand new trans that I am using for my gte vvti I am working with George and joe that have plates out for sr20's and ka that work great.
I order a spec twin plate but they had the wrong clutches in it when they shipped so I am waiting on replacement nissan ones along with the correct throw out bearing.
Old 02-14-13 | 05:21 PM
  #171
afro88's Avatar
afro88
2JZ coupe- Keep us updated on George's work. I'm familiar with his fab work and would like to see what he comes up with. I'm sure he'll work out something for the shifter as well.
Old 02-14-13 | 08:07 PM
  #172
Halon's Avatar
Halon
Adapter on and flex plate on with bolts finger tight:
3 sets of hardware that came with the flywheel adapter. Pretty sure he said to just use one set, which will replace the actual flexplate bolts. waiting for confirmation
Holes all lined up perfectly so far!
Old 02-14-13 | 11:29 PM
  #173
airfed's Avatar
airfed
Has anyone with a tranny got a side by side view of the w55/58 next to the cd009. Is the cd009 alot wider where the casings meet in the front of that black cover plate? It looks like its gonna be a tight fit on my is300 in that area.
Old 02-19-13 | 12:29 AM
  #174
iridebmx's Avatar
iridebmx
im back with my trans. finally pulled the plug and started getting everything. THIS IS 1UZ related. HALON IS 2JZ.
milled bellhousing courtesy of kgmade in marrietta ga
shortened shifter courtesy of kgmade in marrietta ga
swap1uz adapter kit with concentric slave spacer, pilot spacer, and hardware
pedals on the way thanks to 8052jz
Still have the flywheel(3sgte lextreme), clutch disc(HD ACT sr20det), pressure plate(HD ACT 3sgte), master cylinder(driftmotion), clutch line(driftmotion) and shifter(oem) to buy. at a bit of a standstill though until i find out what the CEL on my car is and buy new front lcas... my car loves to break on me when i spend money for something fun.
Just thought i'd add my swap in the mix. wont have many more updates after this unless my friends keep sending me pics
Old 02-19-13 | 03:37 AM
  #175
PseudoK's Avatar
PseudoK
so as far as the speed sensor... has no one found a solution for the SC?
Old 02-19-13 | 09:33 AM
  #176
iridebmx's Avatar
iridebmx
supras and new sc's have abs speed sensors in their hubs, replace a hub with one and buy a abs speed sensor converter. its a hassle, but nissan on toyota your going to have a something bit you in the butt. thats as much as i've come up with no idea if it will really work or not.
Old 02-19-13 | 11:21 AM
  #177
Halon's Avatar
Halon
Have a pic of the modified shifter linkage by chance? Did you just cut the arm part out and weld the two U pieces together?
Old 02-19-13 | 11:32 AM
  #178
iridebmx's Avatar
iridebmx
not my picture but that is exactly what is done.
Old 02-19-13 | 12:17 PM
  #179
Ali SC3's Avatar
Ali SC3
CL Folding 100000
I don't see the flywheel adapter thing for the 2jz on that website.
makes it alot more interesting with the flex plate and adapter allowing standard 350z stuff to be bolted on.
Old 02-19-13 | 07:03 PM
  #180
Halon's Avatar
Halon
Just contact him directly. He may still have more.
These pics are in my build thread, but figure I'll just copy em over here too for reference sake.
Adapter on:
Trans attached:
Test fit-up:
