350Z trans adapter?
#184
350z 6 speed cd009 will not fit a IS300 chassis tunnel starting with firewall and going full duration of the tunnel. https://www.clublexus.com/forums/is-...sion-swap.html
#191
Funny you should ask., I just updated post #159 with where I'm at currently. I will try to keep it updated as time goes on:
https://www.clublexus.com/forums/7745788-post159.html
#192
Couple updated pics.
I welded in two longer bolts to act as studs for the starter, and drilled the starter threaded holes out. Should work nicely. You can see them in the upper left of the first pic kinda. Also in the pic is the OEM flex plate, and the flywheel adapter plate installed (loctite).
Pic of flywheel / clutch setup fully installed.
Big fawker
Wasn't easy, but she's in. Don't have the trans mount yet, there's a jack under there holding it up for the time being.
Big fawker
#194
Yeah if you just keep them as bolts, you will have to remove the trans to replace starter with this adapter plate. So I'd definitely say making them studs is a must for this setup.
As for the trans mount, sounds like Collins will have a trans mount solution for purchase here soon.
#195
^^ agree with that do you think changing the starter is possible without dropping the transmission, or do you think you can access it but remove the trans crossmember. I have pretty much made up that I'll be doing this swap as soon as I get the money to buy the stuff off collinsadapters.com
