Im about to start working on my 1993 sc300
Old 04-19-12, 09:34 AM
SCPuryear
SCPuryear's Avatar
Default Im about to start working on my 1993 sc300
I want to get started on my sc300 im try to figure out how to remove the engine i need to know the steps on doing that:
Old 04-19-12, 10:33 AM
NaturalJZ
NaturalJZ's Avatar
drain oil.
Old 04-19-12, 11:02 AM
bodydrager
bodydrager's Avatar
Drain transmission oil.
Engine oil doesn't need to be drained if your not tearing the engine down for a rebuild.
Disconnect engine harness inside car.
Disconnect Exhaust.
Disconnect power steering line and harness wire.
Disconnect wires on the starter.
Take off fan shroud and fan.
Take bolts off on transmission crossmember mount and motor mounts.
Label vacuum lines and fuel lines and remove them.
Remove transmission lines if automatic.
Drain coolant and remove hoses.
Remove engine!
Old 04-19-12, 11:03 AM
xxtoobsxx
xxtoobsxx's Avatar
plasma cutter...do it
Old 04-19-12, 05:54 PM
jmorando05
jmorando05's Avatar
Where are you located? Might want to ask for help if never done before.
Old 04-19-12, 07:00 PM
vugy79
vugy79's Avatar
jmorando has the idea you want someone there that has some experience with such a thing or bite the bullet and take it to a reputable shop otherwise you may get in over your head and be stuck having to take it to whatever shop will take a halfway done project and try and charge you way more than you should be paying for it!
faulks2
07-10-18 02:39 PM
Cthao
03-14-18 09:55 AM
Eliaquim
07-20-16 07:50 AM
k311in
07-13-11 02:17 PM
JT8JZ31C5R
07-15-06 12:11 PM
Quick Reply: Im about to start working on my 1993 sc300
