exhaust help sc300
exhaust help sc300
I have a 92 sc300. I was wondering if the sc400 exhaust would be an upgrade to sc300. And if so would it be worth it?
thanks for the input.
if your looking for a cheaper way to get more power via exhaust i would suggest getting a magnaflow Y pipe and flowtech raptor mufflers you can order it all offline or get them special order from most auto parts stores i know pep boys carries them the y pipe should be less then $50 and the mufflers are about $25 each. as far as sound they sound just like a magnaflow they are a streight through muffler just like most import mufflers are and for horsepower the most power gain you will get is by swapping out that Y pipe but the mufflers help too not to mention that they are much lighter dont forget to deleat your resonators.
so to recap parts is all together 100 or less and labor a good muffler shop should be able to swap your Y pipe deleat resonators and swap your mufflers for less then $100 i doubt it would take an hour to do all of that they might charge a couple bucks for the test pipe tho. good luck
gqchynaboy
Performance & Maintenance
19
12-04-09 02:38 PM
