electrical question/ trouble
Done some searching and can't seem to find a good reason from my troubles.
I have a 93 Sc300 M/T stock setup.
When I turn on the AC or the headlight the can stalls out. I can hear the fuel pump shut off.
I have changed out the battery, upgraded the alternator, changed the stater, upgraded and changed out almost all of the engine bay grounds and even added a few. The problem started a few days after I install a new AC compressor but now has added the headlights. I have also changed the fuel filter and even tried the 12v fuel ecu bypass. Cleaned the IAC and check the TPS
Oh and it doesn't matter if I am at idle or driving.
Looking for any ideas - suggestions- wild guess at this point.
ac, bypass, clublexus, diagnostic, diagrams, ecu, electrical, fuel, headlights, hearing, sc300, stall, static, turning, wiring
