TDC cam adjustment.
Old 04-20-12, 03:39 PM
CAsc300
CAsc300's Avatar
Default TDC cam adjustment.
Hey guys im a little confused here i am wanting to adjust m cams beacuse my mechanic messed with my cam timing. but im reading here you set your motor to tdc with cyl 1 at the top. when i set my motor to tdc the cams are no where close to the marking points they should be at. and that would cause a bent valve and destroy the motor correct? so my question is it supposed to be on cyl 2? or is my motor just completly outa wack. please respnd asap working on my car as im typing. thanks!
Old 04-20-12, 09:16 PM
GS4_Fiend
GS4_Fiend's Avatar
If your timing is off, your valves are bent already.
Old 04-20-12, 10:32 PM
chingpo05
chingpo05's Avatar
if its the vvti motor that is. i dont recall the 2j non vvti being an interference motor. rotate the crank twice before you get to tdc and check it again.
Old 04-20-12, 10:39 PM
CAsc300
CAsc300's Avatar
Valves are not bent so I think im ok I figured it out
Old 04-21-12, 01:59 AM
soarer13oy
soarer13oy's Avatar
Set piston to TDC take off timing belt rotate the cams to correct position and reinstall timing belt. What kind of mechanic would mess up timing?
FrankT
11-10-17 11:09 PM
sandiegan
12-04-10 09:19 AM
MJHSC400
02-11-07 12:31 PM
Mike
GS - 1st Gen (1993-1997)
06-24-03 10:47 AM
GSXRAWD
06-22-01 10:08 PM
Quick Reply: TDC cam adjustment.
