Smog test failed at low speed
I would check to see if the car is in fuel control first. Looks like your cats are not storing the oxygen like it should be. Its leaking some oxygen. Get the cat tested if it really needs one. This is not something you can do yourself. You need a certified mechanic to do these tests.
Thanks in advance!!
Techmotion
09-17-13 06:53 AM
