first time running MT et streets VID
Old 04-27-12, 10:59 AM
SC300_704
SC300_704's Avatar
Default first time testing out MT ET Streets (VID)
just like the title says. crappy launch and bad 60', was hoping to break into the 7's. tires were set at 20 psi and launch control was at 4500 rpms. was gonna do another run w/ launch control set at 5500 rpms but while i was doing a burnout the engine back fired and messed up the wastegate. but all is good now, hopefully i can go do a 1/4 run today.
EDIT: here's my 1/4 run from today. didn't do as good as i was hoping for but did get a good launch though. clutch pooped on me on 2nd run so i had to let off early.
1/4 - 12.6 @ 112mph
1/8 - 8.2 @89mph
1.962 60'
Old 04-27-12, 12:45 PM
99SC42
99SC42's Avatar
Nice! The car sounded great .
What's the rear setup?
Thanks for sharing.
Old 04-27-12, 01:17 PM
HiPSI
HiPSI's Avatar
Looks like it still trapped 98mph? The power is there just need more seat time and figure out your sweet spot.
Old 04-27-12, 02:29 PM
soarer13oy
soarer13oy's Avatar
Awesome vid just gotta get the start down. Make sure u get vids of the 1/4 pass
Old 04-27-12, 02:39 PM
stockhatch
stockhatch's Avatar
Car sounds great man. Once you nail the launch it's going to turn some great times.
Old 04-27-12, 09:16 PM
SC300_704
SC300_704's Avatar
Thanks for sharing.
stock w58 and rear end
actually it was only 88 mph. for some reason w/ these new tires my mph has gone down compare to street tires.
thanks man!
thanks! i'm pretty sure i could've done a better job if it wasn't for the clutch.
Old 04-28-12, 08:18 AM
HiPSI
HiPSI's Avatar
thanks man!
The better 60 ft's and traction the less mph you will have but faster ET's .
BTW are you making similar power in these runs compared to your sig whp? The clutch is probably your biggest drawback at the moment from low 12's.
Old 04-28-12, 08:33 AM
SC300_704
SC300_704's Avatar
that makes sense. i was probably making about the same power.
Wicked SC
Florida Lexus Club
03-18-10 09:28 PM
T51R
36
06-02-03 10:21 PM
Angel
SC- 1st Gen (1992-2000)
16
10-10-02 11:41 AM
Quick Reply: first time running MT et streets VID
