Can someone take a look at these pictures please.
i want to know from someone knowledgeable what the cause of this leak is from. i replaced valve cover gaskets already. Thanks
http://s193.photobucket.com/albums/z...eru/clublexus/
i did clean it up before driving it again to see where it is leaking from. I cant see where it is coming from even if im down there checking for it to leak.
i cant even tell what im looking at in your pics. go to the store and get a little bottle of engine oil dye and a black light. take the time to clean the oil residue with brake clean. mix the oil dye in with how ever much oil u need to top it off and run around town do your errands and come back and use the black light. if you do not see any signs of the dye continue to drive and check until you do follow the trail of dye back to the location of the leak.
dubstatus
GS - 1st Gen (1993-1997)
12-07-16 07:27 PM
Measured
06-05-15 02:30 PM
dbui
RX - 1st Gen (1999-2003)
06-03-15 05:37 AM
