Need Help!! Electrical probs.
Old 04-28-12, 03:44 PM
2JZwannabe
2JZwannabe's Avatar
Unhappy Need Help!! Electrical probs.
I have a 99 SC 300 stock motor.I have a crank but no start issue. Hooked up a scanner to it had no comm to PCM.I noticed that the check engine light does not light up.Both EFI fuses are good IGN fuse is good swapped the EFI relay with the defroster ,same result cranks no start.Does anyone know what wires at the under hood fuse box I should be checking and what wires at the PCM should turns the PCM on??
Old 04-28-12, 04:13 PM
Nova
Nova's Avatar
i would hold off on the pcm for right now. u NEED 3 things for that car to start, compression, fuel and spark i would verify that you have all three before continuing and further
Old 04-28-12, 05:22 PM
2JZwannabe
2JZwannabe's Avatar
Yeah but if the pcm is not turning on then you won't have spark or fuel.
Old 04-28-12, 06:10 PM
wth98sc
wth98sc's Avatar
you have gas?
Old 04-28-12, 08:09 PM
2JZwannabe
2JZwannabe's Avatar
yes car has gas
Old 04-28-12, 08:42 PM
GS4_Fiend
GS4_Fiend's Avatar
There is a fuse for the Check Engine Light. It's one of those ECU fuses located in the engine compartment. I think it's fuse 7.5 rated. Check all of the fuses to be positive. When CEL is working again, it should start. Unless, the CEL has a burnt bulb. GL
Old 04-28-12, 09:01 PM
2JZwannabe
2JZwannabe's Avatar
Yea checked that fuse it's the efi fuse which has power. What I need is wiring diagram to find out what wires turn on the PCM
Old 04-28-12, 09:14 PM
GS4_Fiend
GS4_Fiend's Avatar
The OBD 2 (DLC) fuse is on the driver side, for 7.5 AMP Your best bet is to check ALL fuses. Which ever is burnt replace. Start from engine compartment then driver kick panel/fuse box.
Old 04-29-12, 09:39 AM
Nova
Nova's Avatar
exactly why you should check to see if you have either.......
Corey513
06-19-17 05:26 PM
Vitalxs
01-04-17 08:56 PM
mak89
SC- 1st Gen (1992-2000)
05-08-11 03:38 PM
SC51
04-29-10 10:03 PM
kevinindy
08-06-07 08:23 PM
Quick Reply: Need Help!! Electrical probs.
