Getting more power out of a sc400?
Old 05-02-12, 02:30 PM
claytons91
claytons91's Avatar
Default Getting more power out of a sc400?
How much power can you get out of a NA 1uz for cheap?
Cams?
or would turbo be the best way to go...?
thanks guys.
Old 05-02-12, 06:20 PM
Bassrocker
Bassrocker's Avatar
cams are not cheap your looking at at least 500 dollars if not a lot more (you need FOUR of them after all) plus there is the install and tuning of them. that being said a cam would give you a significant upgrade along with more fuel i imagine. but perhaps thats not the first place to start
Old 05-02-12, 06:27 PM
hovsc400
hovsc400's Avatar
best advice i have for you is to search there are a number of ways to get more power out of the 1uz and they all cost $$$$$ turbo, supercharger, ITB's, cam and head work, goggle 9300 rpm 1uz and see all what he has done to the car. Visit lextreme there is alot of info on the uz there
oh yea and did i mention it cost $$$$$$$$$$$$$ to get power out of the 1uz
Old 05-02-12, 06:44 PM
Bigzavs
Bigzavs's Avatar
best way to get power in an SC400, JZ swap it.
but seriously, the UZ doesnt have the amount of aftermarket support the JZ has, so things are not going to be exactly "cheap". first things you should worry about are opening up the Intake and exhaust systems. cams wont get you anything unless your I/E systems can flow the extra air they will allow for.
Old 05-02-12, 06:50 PM
DJVe
DJVe's Avatar
why do people keep posting this question? do they not know what the search is?
Old 05-02-12, 08:11 PM
g4ebguy90
g4ebguy90's Avatar
I work at a place that deals with stainless steel. I plan on using a gasket to make my own header collector and have them weld the pipes etc etc. Probaly cost like $20 in scrap.
Old 05-02-12, 10:28 PM
ajmccarrel
ajmccarrel's Avatar
I'm the Controller of a tube bending shop that makes aircraft parts. It's not quite that simple. There are all sorts of considerations besides just slapping something together. You need to consider fluid dynamics, the ability of the material to handle the repeated heat stress, etc.
If someone can get decent drawings, as in professional grade specs, I'd see if it'd be worth it to have our shop build headers.
Ryeli
09-09-11 05:42 PM
luissc400
SC- 1st Gen (1992-2000)
12
07-18-11 02:25 AM
Wangan_sc
18
12-13-09 07:05 PM
LEXBOGGY
07-04-04 11:30 AM
Quick Reply: Getting more power out of a sc400?
