Engine loud ticking from valve area w/ video
05-07-12, 11:13 AM
Started about 2 weeks ago. sc300 140K.
Sound is coming from the front (facing the bumper) area of the valve cover on the right side.
Here is a video w/ sound.
Anyone know?
05-07-12, 11:20 AM
That sounds pretty loud for a valve. Sounds deep. usually when the hydraulic lash adjusters fail they click... tick tick tick tick.
05-07-12, 12:01 PM
Super Moderator
if you are sure it is coming from the upper part of the engine or head area , make sure that your camshaft bolts are not loose, if they are not then probably valve lash/clearances but if you didnt change cams then I dont see why valve lash would be the issue.
05-07-12, 01:43 PM
Can be piston rings, valve lash or piston pin. Get it checked out.
05-07-12, 03:19 PM
Pull the accessory belt and run without it to see if its a driven accessory before you go tearing into the engine.
05-07-12, 03:42 PM
Its a knocking noise. Most likely engine related
05-19-12, 07:11 PM
Turns out the cam pulley was loose and rattling. It wore down the steel on the cam so we fitted a steel shim and tapped it in to balance it out.
05-19-12, 07:21 PM
Good find.
gtknoles
03-12-14 02:31 PM
Superczar
08-19-09 09:02 AM
scfocus
Performance & Maintenance
23
07-29-08 11:51 AM
Lexozz
13
09-16-07 12:41 AM
Woogie
01-16-05 10:43 PM
250 ,
97 ,
engine ,
engine ticking ,
es ,
is300 ,
lexus ,
loud ,
louder ,
news ,
tick ,
ticking ,
valve ,
valve ticking ,
valves
