A/C Leak.. Possible O-Ring replacement?
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Hey guys I had my A/C recharged and it leaked out. I am guessing its a O-Ring that is bad so I was wondering if any one run into this problem or know if there are any other seals that could/should be replaced. Thanks!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
1JZ Single SC400
There could be numerous possibilities. I would add a cheap can of freon with dye and let it run through the system. Then get those ugly yellow glasses and check for leaks with a black light. If you take it to a shop, they will pull a vaccum test on it and try it that way.
The leak was coming from the front of the compressor it looked to be the line but I wasnt using the dye so I could not get close to it =/
Bighead222^ where did you get the O rings for the A/C?
Hi,
I saw your post on replacing O-Rings in your ES300 A/C system. I measured one for the Condenser manifold and it measured 7/16 ID, 1/16 cross section but when I replaced it with a new HNBR they do not seal properly. Can anyone help identify the proper o-rings for the condenser and compressor lines?
Thanks. Carey
Thanks. Carey
