Will a Magnaflow 14832 fit an SC400?
Does it HAVE to be a 14829? I know the 14832 is a shorter tip, but can't more pipe be added at the inlet to make up the difference?
Is it going to be a problem, or will it fit just fine? I don't want to put my exhaust guy through the ringer if this is going to be significantly difficult. I just had a mishap backing up into a piece of concrete and wanted to replace my broken mufflers and the 14832's were like $40 less a piece and the only real difference seemed to be the tip. I just wasn't sure if it would be worth it to spring for the extra tip if a bit of extra pipe in the inlet would be fine.
