4" dp fitment
4" dp fitment
Im having issues getting my 4" dp/midpipe that i bought off a member on SF. Seems like i would have to take off the manifold put in the dp and then put the manifold and turbo on. Below i have pictures, do you guys think cutting the dp and making it a 2pc work without having to remove the manifold. It would be a pita to have to do this all the time.
Yes definitely cut it into two pieces, try and use a vband connection as it will be easier to bolt down. This will fix your issues. On the top pictures I would hack it at the 2nd weld bead left to right. Depending on the condition of that pipe you might be better off having a custom one made.
Exactly what those two above me said ! it will not work , till you cut it and put a V band between the two ( dp &Mp) it will always be a Pain to install and remove.
And you know the BWS366 doesn't come with 4" V band it's Marmon Flange that's on it , so you will either have the flange machine to a 3.5" V band or you will have to buy a marmon flange which is $70.
I would buy the marmon flange because it's cheaper and works great, by the time you do the V band mod , buy the V band and clamp you are looking at 150-200.
I had mine done and i can tell you it wasn't cheap, i am building another gte right now but i am going with the marmon flange and clamp .. it's cheaper.
I can start it and rev it but it needs to be tuned because i put 550cc in there running way too rich. I have been slacking though lol. I ordered some ccw classics also so im waiting for the tires to arrive.
It revs a lot smoother and is more responsive now. This was when i first started it which was a month ago. Open downpipe. Still gotta sand down the spark plug cover and paint it.
Todd_A
SC400 / 300 Classifieds
02-14-07 12:49 PM
