Craigs list R154 trans ?
Im doing a Manual R154 swap on my 98 SC400 , I am looking to buy a Soarer trans , I see a few R154 trans on crags list, supra , 7 bell housing , my question is there a specific part # i need to look for so i don't buy the wrong trans ,
I know actual soarer trans are not an easy find in los angeles
Im in the same situation looking for r154, but not from mk3
I know it's almost impossible to find one out of the soarer on cl with extended shifter housing so you don't have to cut a hole in the tranny tunnel. If I'm wrong somone correct me. 7mgte tranny is a little different than the r154 out of a soarer 1jz
If you go 7m route u need to keep your 1uzfe bell housing and have an adaptor made to match your 7m with a custom throw out bearing and a clutch slave cyl or go quantum auto hydrolic bearing and lines. You'll have to do that with either trany or go custom since there is no plug and play option $$$$ and swet.
Here's what I mean:
https://www.clublexus.com/forums/per...adness-16.html
Look at how this gentleman cut out the hole in the tunnel. That's basically all you need to do. It's not difficult to do.
I would read that whole thread if you are serious about doing the swap.
