95 Sc400 Check Engine Light
05-22-12, 09:32 PM
So my 95 Sc400 is throwing a code 31 on the check engine light. Anyone know what it can be? Please..
05-22-12, 09:47 PM
31 code is air flow meter signal....
05-22-12, 09:53 PM
Thank you. Was browsing the web and came across that also. By any chance do you know how I can fix it or what needs to be done?
05-22-12, 10:01 PM
Could be MAF and check there if there is dirt then clean it .
05-22-12, 10:36 PM
Quote:
Originally Posted by
cleansc4
Ok thanxs I appreciate it. Ill check it tomorrow.
04-14-14, 06:03 PM
Same issue but
Replaced maf on 95 sc4 new one has wires on it and cel and trac lights won't turn off? How do I reset them
04-15-14, 07:02 AM
In Recovery Mode
moneysc400
You remove the negative battery cable for 5 minutes. That will reset all settings and warning lights.
04-21-14, 09:45 AM
Will that also reset ecu?
04-21-14, 09:51 AM
In Recovery Mode
moneysc400
Yes.
10char
ychachad
16
02-11-16 11:38 AM
marig
Performance & Maintenance
11-27-12 02:20 PM
Scotty93
09-10-09 09:17 AM
kenmonster
12
07-10-09 04:01 PM
Niko1981
03-07-08 07:07 PM
24 ,
2k ,
31 ,
400 ,
95 ,
check ,
code ,
engine ,
engone ,
giving ,
house ,
lexus ,
light ,
sc ,
sc400
