FMIC w/ IC?
are you doing it for a single turbo or stock twins?
this is for the single turbo:
![](https://sphotos.xx.fbcdn.net/hphotos-snc6/230090_10150167974642772_7267847_n.jpg)
fmic dimensions: 24"x9"x3"
universal ebay kit. just look around for dimensions around that. its pretty easy, to mount it just tap into the crash bar. as for the bends you use most of the pipe, i only had to cut 4 pieces i think
1JZ Single SC400
I ran my 3" under the passenger side headlight. I also had to remove a small black tab under the light for it to sit properly. Nothing that affects the headlight. I ran the other side different than the picture above. I had to maneuver the AC lines a little to clear the 3". If you go with 3" you will need a reducer for the throttle body. 3" to 2.75".. Look at my build thread toward the end for more detailed pictures... GL
IneednSC
SC- 1st Gen (1992-2000)
01-27-14 07:07 AM
bighitbike
SC400 / 300 Classifieds
07-06-07 01:13 PM
