1j crank walk
Old 01-30-14, 11:25 AM
  #61
99SC42
99SC42's Avatar
Nick-You are 100% correct , they don't have that issue in JP because 98% of them are running twin or triple discs.
Ali- If you do the 350Z get a twin disc clutch , if not do waste your time machining your bellhousing Because you wear out your input shaft bearing because the dowell pins will not be used to line everything up.
I know a guy that's making 830whp on 1jz with S366 with that trans and after talking to him i decided not to mess with that setup.
Old 01-30-14, 02:58 PM
  #62
Ali SC3
Ali SC3's Avatar
so the twin disc will make up for the milling of the bellhousing. very interesting.
I just found out they make a twin disc for the w58 that will hold same power as I have right now, but its 1800, that almost like a r154 swap.
I wonder though how much abuse a twin disc w58 can take over a regular setup. probably the torque will still break the trans while the clutch holds strong.. lol
Old 01-30-14, 06:00 PM
  #63
babowc
babowc's Avatar
Does the machining the bellhousing omit the dowel pins?
Old 01-30-14, 07:31 PM
  #64
99SC42
99SC42's Avatar
Well here's the thing. You have to machine 1/2 off the bell housing. When you do that you loose the dowel pin holes and his adapter doesn't have any anyways. So you're left with the bell housing bolts to align the input shaft with the crank center line and there is just to much error. I've wore out two input bearings in a short amount of time just because misalignment.
This is from my buddy^^
Old 01-31-14, 07:51 AM
  #65
Ali SC3
Ali SC3's Avatar
always good to hear from someone who has tried it. never thought about that misalignment but it is an adapter so it makes sense. gonna go with a r154 or solstice trans then.
Old 02-13-16, 10:16 AM
  #66
LoveSCs
LoveSCs's Avatar
bumping this for a good read.
I just ordered my Collins adapter kit for my cd009 swap. I went with the ACT 6 puck kit good for 670 ft lb. I am concerned now after reading this thread.. wish I would've come across this sooner
Ozzzzy
03-21-15 06:24 PM
rollexus
06-14-12 04:00 PM
Superjatt
SC- 1st Gen (1992-2000)
18
05-24-10 07:58 PM
SC300T
04-02-08 01:05 PM
Quick Reply: 1j crank walk
