1JZ swap/SC400 A/C not kicking on
Old 12-29-12, 03:23 PM
DoomLight
DoomLight's Avatar
My brain is all scrambled. I can wait. I still don't drive it daily. It just sits there. I was just tinkering with the car today.
Old 12-29-12, 06:30 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Whats left with it??
Old 12-29-12, 09:37 PM
DoomLight
DoomLight's Avatar
Just basic stuff. I want to install the BC 264 camshafts, I need to put in a bigger fuel pump, clean my injectors and fuel tank schedule a re-tune and hope I get above 500 horsepower. If I mirror your setup I'm sure to succeed.
Old 04-10-13, 09:22 PM
jintei
jintei's Avatar
sorry to bring an old thread back to life. I have the same issue but mine is 1JZ VVTI. can you help me with this? thanks.
Old 04-11-13, 07:31 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Did you try my method exactly?
Old 04-12-13, 07:07 PM
jintei
jintei's Avatar
My mechanic told me that he tried switching the AC controller from his sc300 into my sc400 and it didn't work. He also tried to adding the relay switch but he doesn't exactly know where to start. Not to mention he is not exactly sure which car the 1JZ VVTI came from. Any idea what I should do next? Thank you so much.
Old 05-03-15, 05:54 PM
megamax
megamax's Avatar
MARK!!! is ur ac still working??
Old 06-08-15, 07:42 PM
megamax
megamax's Avatar
guys guys guys!!! so in terms of PRE aem, how do I wire this up(feel free to use windows paint to make me a diagram).
Old 06-09-15, 08:29 PM
megamax
megamax's Avatar
wow, anyone?? what happened to this site?
Old 07-03-15, 09:00 AM
megamax
megamax's Avatar
well thanks guys(not really). I didn't have to re-wire anything and all I had to do was charge the system. so thanks again guys!
Old 09-03-15, 03:56 PM
megamax
megamax's Avatar
so NOW I have to wire in my ac pins for my aem jumper harness. I will supply pics when I get this done(hopefully soon).
Old 04-15-16, 11:25 AM
megamax
megamax's Avatar
ac switch input= multiple options. I just selected "switch always on"?
Old 04-17-16, 10:51 PM
megamax
megamax's Avatar
paging mark!!! which option did you use?
Old 04-18-16, 03:18 AM
gerrb
Super Moderator
gerrb's Avatar
Jim - do you want Mark's phone if you don't have it ? I got it .
Switch option depends on what is available .. you can use any LS (low) switch that is not used .
Old 06-24-17, 08:47 AM
megamax
megamax's Avatar
bump, having the same issue again!!!
AZOliT
SC- 1st Gen (1992-2000)
10-17-13 11:54 AM
Lokz
Build Threads
33
05-12-13 03:17 PM
wilsonsan
GS - 1st Gen (1993-1997)
04-11-11 01:06 AM
jinsoku3g
05-15-10 09:57 PM
MadMaxxNA
08-09-05 03:50 PM
Quick Reply: 1JZ swap/SC400 A/C not kicking on
