1jzgte people come here!!! problem eith tranny mount!!
Old 06-02-12, 06:23 PM
TLsc300
TLsc300's Avatar
Default 1jzgte people come here!!! problem eith tranny mount!!
So i did my swap and everything is in beside I need to mount up my tranny but the tranny mount doesn't line up with the old... I'm using the w58 tranny mount. So help the brother out cause I'm trying to drive my car but I need that to bolt up. I'm using my phone but here the picture its in my Facebook. http://m.facebook.com/?_rdr#!/photo....ser=1163637773
Old 06-02-12, 06:34 PM
JDMb16bEG6
JDMb16bEG6's Avatar
Loosen up the motor mounts and brackets maybe start the bolts ten tighten the mounts and bracket up? I'm in the middle of my 1jz vvti swap right now
Old 06-02-12, 08:33 PM
INTIMAZY
INTIMAZY's Avatar
Sorry not sure if the mounts are the same or not. I had an issue with my R154 trans mount. The passenger side motor mount had "hung up" and didn't settle all the way down. I had to loosen the motor mounts and let the motor drop down before the trans mount would line up.
Old 06-02-12, 08:44 PM
StiCk3
StiCk3's Avatar
can't see the pics, but from my experience i didn't have problems with the mount lining up. should line up, you sure your mount is on right? crossmember facing the right direction?
Old 06-02-12, 10:29 PM
djeleets
djeleets's Avatar
I had the same problem...I'm doing the same swap right now ...I just loosen the motor mounts then push the eng back and it wrkd...loosen the tran mount also or it could break if it is old like mine did.... Lol waiting for new from driftmotion...
Old 06-11-12, 06:10 PM
TLsc300
TLsc300's Avatar
i found out that the mount was on wrong lol. so i change it and it fit fine =)
Old 06-11-12, 06:11 PM
TLsc300
TLsc300's Avatar
i got it to work after changing it. but that suck that your broke though lol.
Helogadget
06-19-15 02:05 PM
GS4TEK
07-14-12 11:53 PM
rapollon
GS - 1st Gen (1993-1997)
12
09-19-11 10:54 PM
scviolence
SC- 1st Gen (1992-2000)
07-10-10 09:43 AM
O. L. T.
SC400 / 300 Classifieds
04-14-06 06:58 PM
Quick Reply: 1jzgte people come here!!! problem eith tranny mount!!
