4 runner cap and rotor
Old 06-08-12, 08:54 PM
2JTsc300
2JTsc300's Avatar
Default 4 runner cap and rotor
What year cap and rotor do I need for my dizzy. My T67 is too big and I need to free up some space for the 4 inch intake
Old 06-09-12, 11:20 AM
chizz95
chizz95's Avatar
93 v6 4runner pretty sure I'm using it,out of the 3 bolt holes can only use 2
Old 06-09-12, 12:14 PM
kevint2
kevint2's Avatar
Yeah 93 is the one to use with the stock wire,If you want to up grade to 8-10mm wires you can use the 88-89 cap
Old 06-10-12, 07:48 AM
2JTsc300
2JTsc300's Avatar
cool thanks, im about to order one now
Old 06-12-12, 04:28 AM
XplicitlyR
XplicitlyR's Avatar
http://forum.clubna-t.com/showthread.php?t=4921
Old 06-13-12, 02:22 PM
Ali SC3
Ali SC3's Avatar
woah, slow down there buddy. It's just the 4runner cap, not the rotor.
Old 06-13-12, 10:31 PM
sj408
sj408's Avatar
Hey ali, do you have to re time anything or just slap on the 4 runner cap and go
Old 06-14-12, 10:08 AM
Ali SC3
Ali SC3's Avatar
you can usually just slap on the 4runner cap and go, as the timing is controlled by the ignitor.
when the ignitor fires the rotor needs to pointing to the right part of the cap, and while the 2 caps have been shown to not be in perfect alignment on all 6 points, its close enough to where the spark gets dealt out properly.
so just slap it on it should be fine, make sure you get 2 of the 3 bolt holes to match, or its not on properly.
try not to superman overtighten the 2 screws either, it may distort the cap.
Ali SC3
Ali SC3's Avatar
SC300_704
06-23-10 06:27 PM
VJZ
04-05-08 08:37 PM
Vmoney
GS - 1st Gen (1993-1997)
03-22-06 09:54 PM
Taka
08-31-03 11:07 AM
Quick Reply: 4 runner cap and rotor
