Fuel Filter Advice needed ASAP
I did a DIY a while back. The key is to crimp the rubber portion of the fuel line right underneath the fuel tank. Fuel will not get past that and you can take your time changing the fuel filter with out chemical burns.
https://www.clublexus.com/forums/sc-...sing-fuel.html
You can use a stock 300ZX TT filter. Here's a link if you go fuel hose route...
http://www.vegasdrift.com/forum/inde...78.0/wap2.html
I don't know why pics aren't working, but maybe they will for you. Good luck!
get a metric to -6 fitting and ss fuel line with an inline fuel filter and replace your old steel lines ; ) prob cost around 250 bux and if you ever want to go turbo an extra inline fuel pump could be added.
Thanks all, I'll check into the TT 300 filter if I decide to change it out.
No need for -6 line. If I ever do anything more than bolt ons it'll be a 100-150 shot.
-Will
-Will
Well this thread was timely. My SC400 stalled on the freeway this morning. I limped off an exit and it was barely running. I really thought the CEL was on when I had it towed to a shop, but they said no. The car ran fine when it got there....they said the only thing they could find wrong was that some azzhat had put the car on a lift and bent the fuel line and filter. Probably last week when I had the tires rotated and I just hadn't had it up to speed yet. So the fuel line isn't leaking, but it's way bent/kinked. The mechanic wants to replace the filter and the entire hard line. I told him why not just cut out the bend and put in rubber line and they said you couldn't do that. So.....this thread not only shows me that there IS a rubber line up there, but also that a 300TT filter might work. Bet I could just buy several feet of rubber line and the TT filter and swap the whole hard line piece out. Betting it's less than the $300 the shop is quoting too.
No need to go trying to replace multiple feet of hose.
-Will
Yep, I have both the cutter and flare tool. I was able to "massage" it a bit and it's running fine again. I'm going to wait until I have an empty tank and a weekend to fix it. It's not leaking though, and I'm not going to turbo it, so it might just go a bit longer on that repair.
Too many house projects at the moment, so car time has to wait.
