Fuel Filter Advice needed ASAP
92 SC400
1/8 tank of fuel
changing filter
It's been 5 minutes, and it's still flowing strong. I've opened the gas cap, jacked the car up, removed the EFI fuse, disconnected the battery, and even jammed something down the fuel filler neck to makesure there wasn't a flap holding pressure (similar to what happens on some F-bodies).
It is STILL flowing strong.
Any help is appreciated
-Will
1/8 tank of fuel
changing filter
-Will
I've worked on plenty of cars before. I have no clue why, but this thing is going to sit here and drain the ****ing tank. I ran to the parts store to get a 14mm flare wrench, and it's still going. It burns the backside of my underarm it's rolling down so much. I'm not this dedicated anymore....I'll change it when it's done draining.
Now why in the hell is it draining the tank? THAT I don't understand. Gravity shouldn't pull it through the pump.
-Will
-Will
It went for over 20 minutes. I haven't hooked the battery back up to check yet, but I have a hunch that I'll have to carry a gas can to Kroger before I can check for leaks....
-Will
-Will
-Will
Well, it's on.....at 200K it still had the STOCK fuel filter. The fittings were so seized I rounded them off with a damn flare wrench.
The metal line twisted a bit. I know that's a restriction. I'll probably cut and flare the lines and use rubber hoses to put a different inline filter in later.
It's in......my tank is empty.
-Will
-Will
Sorry, Ive posted some pretty strong threads on this very subject. Always use the search thread button at the top of each sub-forum. My thread says DANGER fuel filter replacement. They all drain the tanks and the prob. is no ones prepared for it when they start the filter change, including me, twice. The only thing you can really do is run the fuel out by driving as much as possable, then have a large pan to catch the rest when you open the lines. Ive done this on two diff. SCs and they both ruined the line nuts.
My garage smells like the inide of a gas tank now.
You hit the nail on the head.....the rear line nut is trashed.
If I have to do anything to it now, I'll be forced to cut/flare/replace with rubber hose....
-Will
It's so much easier just to cut the fuel filter out than try and undo those fittings. They are all rusted and seized in place. Get yourself a flaring kit and do it right with new fittings.
Here's my DIY w/ pics. The fuel will keep draining til empty. Don't know why....
https://www.clublexus.com/forums/per...ange-nuts.html
Might want to try what this guy said to avoid loosing alot of fuel.
https://www.clublexus.com/forums/869647-post5.html
It's on and working now. I'll likely have to cut it out next time.
For future reference, is there a filter that I can use with rubber hose? I'm thinking I'll probably cut/flare the hard lines, use some 300 PSI fuel hose to connect to that, and install the next FF that way. I'm wondering if there is a stock filter off of something else that might work....a late model mustang or something?
Thoughts?
-Will
Thoughts?
-Will
