1jz vvti wireing question
Old 06-12-12, 01:02 PM
JDMb16bEG6
JDMb16bEG6's Avatar
Default 1jz vvti wireing question
Ok, so I'm just waiting on my throwout bearing clip/reteiner so I can put the w58 back on. My question is there are two wires that are cut that go across the valve cover which are light green and yellow I'm pretty sure those are the colors. Now I'm thinkin those two wires are for the power steering rack? Since I don't see the connector for the power steering rack. I'll have pics up in a few. Also the fuse box wiring and the horn wiring were both cut off on my 1jz vvti. So I cut off the fuse box wiring and horn wiring off my 95 2jzge. Most of the wires are the same, but there's like 3 or 4 wires that don't match on the new motor, and I'm pretty sure there's 1 more extra wire on the new motor, if anyone can help that would be great, ill have pics in a few, as I'm on my droid at the moment, thanx guys
Old 06-12-12, 01:32 PM
JDMb16bEG6
JDMb16bEG6's Avatar
ok, these wires are apart of the old motor that i cut off, those are the fusebox wires and horn wires
Old 06-12-12, 01:35 PM
JDMb16bEG6
JDMb16bEG6's Avatar
and these wires are the wires that are cut off on my 1jz vvti, the igniter harness and ground clip are there, but theres no fuse box or horn harness or clips there.
Old 06-12-12, 02:33 PM
StiCk3
StiCk3's Avatar
idk about the other wires cut, but im 98% sure the first set you mentioned is the PS rack pressure-up switch located on the rack. I know i had to extend mine to the other side of the engine as it was hanging off the opposite side of the engine bay due to the rack location on a RHD car. Just to be sure though, are both your coolant sensors hooked up right now?
Old 06-12-12, 04:39 PM
JDMb16bEG6
JDMb16bEG6's Avatar
Anyone else
Old 06-12-12, 04:48 PM
99SC42
99SC42's Avatar
Those wires looks like your fuse box wires, you may have to trace them and see where they go. those are not the ignitor wires.
Old 06-12-12, 05:00 PM
JDMb16bEG6
JDMb16bEG6's Avatar
I know, the thing is a couple of those wires are diff colors
Old 06-12-12, 05:09 PM
99SC42
99SC42's Avatar
Yes so you may have to chase them back and see where they go.
Old 06-14-12, 08:35 AM
TweakTech
TweakTech's Avatar
12g black wire - starter
12g black/red - +B
solid 18g white wire and 18g black/orange are theft horn.
16g black/yellow - Batt to ECU
solid black 20g - STA to ECU
solid brown 20g - A/C pin 1
20g black/red - WA to diagnostic block (not needed)
20g black/orage - MREL
20g white - ACMG
20g blue - A/C clutch
Any other questions?
Old 06-25-12, 04:16 PM
JDMb16bEG6
JDMb16bEG6's Avatar
12g black/red - +B
20g white - ACMG
You are the freaking man!!!!! Now my question is on the jdm motor where does the yellow and blue wire connect to on the EB1 connector? And the white and red wire on the jdm motor and the white and green wire?
Old 06-25-12, 04:20 PM
JDMb16bEG6
JDMb16bEG6's Avatar
12g black/red - +B
20g white - ACMG
You are the freaking man!!!!! Now my question is on the jdm motor where does the yellow/blue wire connect to on the EB1 connector? And the white/red wire on the jdm motor and the white/green wire? Also on the jdm motor side of the harness there's no black and orange wires. so all in all I have 5 wires that I need to figure out where to connect them to, but that's an odd number I would have 1 extra wire? Please help me bro
Old 06-26-12, 06:55 AM
JDMb16bEG6
JDMb16bEG6's Avatar
Originally Posted by SCSIN
did u wire in ur abs yet
Hmmmmmmmm, tell you the truth I'm not sure
Old 06-27-12, 12:40 PM
JDMb16bEG6
JDMb16bEG6's Avatar
I need this figured out by tomorrow guys
Old 06-28-12, 09:03 AM
cartmill
cartmill's Avatar
wtf tweak out of nowhere???
Old 06-30-12, 04:39 PM
JDMb16bEG6
JDMb16bEG6's Avatar
Motors in today finnaly
Quick Reply: 1jz vvti wireing question
