Are these ebay HKS BOV real?
Old 06-13-12, 02:16 PM
blk&blu*j
blk&blu*j's Avatar
Originally Posted by VinnyQH
get a synapse.
And get a zipper T-3 flange to make the removal of your Precision broken shaft turbo easier to remove after installing above^^^^^^^^^^
Old 06-13-12, 04:26 PM
Parker Gen
Parker Gen's Avatar
Originally Posted by cmh
hks IS top notch quality... u can contact them directly and ask them who u can buy from. they are based out of japan NOT china. the link u posted is fake. the real deal will probably cost u like $250 plus shipping. just a ball park figure.
Thanks will check it out but I was more interested in a hks at the $100 mark.
Originally Posted by blk&blu*j
Sorry I disagree they are not what they used to be.
The Tial BOV is the last one you will ever buy, they use springs to control pressure and the BOV can grow as your needs change as well as having 1 of the largest valves at 50MM on the market in a price range that makes sense.
I run 2 of them do 30psi of boost on a 74mm with a 1.25 rear housing divided and I have 0 compressor surge.
My other car had the same Tial BOV and Gate for over 9yrs and still is operational today as I still see the car regularly.
This sounds great I have been buying all quality mechanical components for my turbo build because I dont want to be going back replacing everything again over and over. I will check out tial bov on ebay.
Originally Posted by Quicksc4
The sound the OP is looking for is from the compressor surging.
GL with that.
Yep I want surge sound without the surge...
lol yea i know... my friends mazdaspeed makes the same sound... closest he will come to a surging sound is from a sequential bov
Are sequential better quality than standard bov or just a different method of release?
Originally Posted by herbSC3RSB
knock offs are looking more and more legit by the day, as far as BOVs go, i've had Blitz r2d2 HKS SSQV turboXS RFL and a Synapsis, my brother has a tial 50mm currently, currently my favorite by far is the synapsis performance wise, however the RFL sounded the best to me
Why is synapsis so good? I will check those out too.
get a synapse.
Same thing why is synapse so good? Same type of quality reputation as tial?
I posted this below video for you to see the difference with no compressor surge on 2 Tial BOVs and a single 44mm Tial WG At 32-33 psi.
this is a car I built for a guy Approx 2 yrs ago bone stock bottom BC 264 cams 1jz single S366 Bullseye T-4 .88 open rear on c-16 through 850cc injectors on a MS2 standalone through a Marlin Crawler equipped R154 with a ACT extreme 6 puck sprung and a DM lightened flywheel.
LISTEN no SURGE.
Sounds like quality to me. I am only going to run 1 bov though.
[/QUOTE]
Old 06-13-12, 04:29 PM
Parker Gen
Parker Gen's Avatar
Had problems with these before? Doesn't sound too good.
Old 06-13-12, 07:37 PM
blk&blu*j
blk&blu*j's Avatar
1 BOV is fine for now put it between the turbo and the intercooler on the passenger side of the car it will allow the fastest release of pressure on shift change or letting off the throttle.
Old 06-13-12, 07:47 PM
cmh
cmh's Avatar
drivers side... his car is a soarer rhd lol
Old 06-13-12, 08:00 PM
blk&blu*j
blk&blu*j's Avatar
Wow thats funny seeing that I have an RHD Supra.....
just contribute it oldtimers
Old 06-13-12, 08:56 PM
Parker Gen
Parker Gen's Avatar
I'm going to check ebay for Tials.
Old 06-14-12, 06:43 AM
blk&blu*j
blk&blu*j's Avatar
Here is the actual web site for Tial products.
http://www.tialsport.com/products.htm
GL.
Old 06-14-12, 03:50 PM
Parker Gen
Parker Gen's Avatar
Thanks for the help everyone. I got a tial 50mm recirculating.
Old 06-14-12, 04:04 PM
blk&blu*j
blk&blu*j's Avatar
Why recirculating? and what spring pressure did you get?
Old 06-14-12, 04:31 PM
Parker Gen
Parker Gen's Avatar
Because this is a street car and in australia all bov must be recirculated. I got 10psi I think. Bought it new in box off someone who never used it for their project.
Old 06-14-12, 05:26 PM
blk&blu*j
blk&blu*j's Avatar
Oh learn something new You might however might want to consider a smaller spring pressure.
Old 06-14-12, 05:44 PM
Parker Gen
Parker Gen's Avatar
Does 10psi mean it will not let air out until the pressure inside the intercooler hoses etc are 10psi or above? I mean vacuum is at negative 10psi? I dont get it. Should it not be instant on vacuum hence less than.1psi?
Old 06-23-12, 11:45 AM
VinnyQH
VinnyQH's Avatar
What's your setup you have? Are you making 700 on pump and meth? And who runs a t3 flange? Guess whoever installed your sh#t sucks if you f#cked your precision turbo up.
Old 06-23-12, 12:51 PM
blk&blu*j
blk&blu*j's Avatar
No ^^^^^^^^^^^^ I'm not the idiot making 700 on pump an meth! E-85 Cost less!!!!!!!!
No Precision (precussion) here Rocket scientist!!!!!
Hes on a T-3 OP. I run over 850 on E. Check the Signature and let me know when your feeling preppy again.
So I guess brains are not your strong point there skippy or else you would know a 74 MM with a 1.25 rear is beyond your comprehension
FYI: I make over 700 in torque big boy!!!!!!!!!!!
Quick Reply: Are these ebay HKS BOV real?
