A340LE code 67
A340LE code 67
Good afternoon,
I have and sc300 and I recently changed my tranny. I bought this a340le without the harness from someone who told me that it would work fine. It seemed to be almost exact as my a340e. After installing it, I realized that it doesn't have an OD direct clutch speed sensor. Of course when I drive around it is giving me code 67. I thought it came out of a 1jz and worked on the sc300, because the guy has an sc300 1jz.
I want to know if anyone else has this problem and how did they fix it? did you bypass/fool the ecu to think there is a sensor etc. There is also a factory blocked off bung where the sensor should go. I just wan to know if there is a simpler solution before I have to drop the tranny to drill that hole out.
Any help is appreciated, thanks!
SunriseTRD
SunriseTRD
koolcat
Performance & Maintenance
03-16-13 12:06 AM
