Does sc300/400 use the same fuel pump
Old 06-22-12, 06:21 PM
NSeagle78
NSeagle78's Avatar
Default Does sc300/400 use the same fuel pump
Will the same fuel pump fit on a SC400 and Sc300. I have a 1992 SC400 and my code says that the fuel pump controler is bad. I am in search of the right fuel pump. I need to take fast action fax or call 478-737-1704
Old 06-22-12, 06:33 PM
xspsi6
xspsi6's Avatar
Yes same pump and why not just do the bypass mod if your fuel pump ecu is bad?
Old 06-22-12, 10:01 PM
NSeagle78
NSeagle78's Avatar
Default still will not start
The fuel pump bypass did not start car does this mean that my actual fuel pump is bad?
Old 06-23-12, 08:57 AM
megamax
megamax's Avatar
or it could mean you aren't getting enough voltage out of the wire to the pump(like me)
Old 06-25-12, 07:58 AM
MooJohn
MooJohn's Avatar
What about jumping the under-hood connector? Connect Fp to B+ and the pump should run any time the key is in the on position.
(I assumed you meant you previously bypassed the FP ECU at the ECU connector)
Old 06-25-12, 08:12 AM
OBEEWON
OBEEWON's Avatar
^^ more info on that?
Old 07-04-12, 09:03 PM
NSeagle78
NSeagle78's Avatar
Default Fuel pump bad
MY FUEL PUMP WAS BAD SO I WILL KEEP THE CAR IN THE BYPASS MODE FOR NOW. i AM JUST RETURNING FROM MAJOR BACK SURGERY SO i CAN NOT DO ANY TEST DRIVING SOON THE CAR STARTS VERY FAST AND POWERFUL.
Modenaro
29
12-11-18 08:47 AM
TechGreek
07-12-11 07:05 PM
clean
SC400 / 300 Classifieds
06-11-07 01:15 PM
SimplyZBes
05-24-07 02:12 PM
O. L. T.
01-22-05 04:37 PM
Quick Reply: Does sc300/400 use the same fuel pump
