Problem With My 1992 Lexus SC300
I just bought my lexus maybe last week its a 1992 sc300 model , it ran good i mean perfect for a week . one day i pulled up to the bank to drop some money off and i turned my LEX off for about 5 min. then i started it back up made a phone call while i was on the phone the car just died on me , i didnt know what it was so i just started it back up and it was good . two days ago i went to work fine after work went to the bank then my house then i left to my friends house , while i was driving the car i gave it gas literally i pressed the gas all the way down but no accelaration what so ever , it was dying on me . i stop in the middle of the road and tryed starting the car back up and it wouldnt , and finally it fired back up but everytime i would try to give it gas it wouldnt and i didnt get far until the car started to die again , now its posted at the house . anyone had this problem before what can it be ? fuel pump ?? the car was driving good and all a sudden this happen ??
no check engine light is on , you mean bad spark plug wires ? can the spark plugs cause the car to randomly stall ? i give it gas but all it does is lose power and stall .
fuel pump ecu!!!!!!
https://www.clublexus.com/forums/per...tures-faq.html
do thus and you should be good.
ignition, air, and fuel...that's what you need to have your car run. check out the components in each of those categories and you should find the culprit.
For IGNITION check your cap, rotor, wires, and plugs.
For AIR check your MAF for loose connections and proper operation. You should also check for any vacuum leaks.
For FUEL check your pump, filter, and fuses.
If necessary check your actual ECU.
This is what I'd do from what I can remember off the top of my head. I'm sure others will chime in if I missed anything.
From experience I had the same problems you had and it turned out to be the rotor. I replaced both cap and rotor and never had a problem again.
If you just got the car make sure to do a full tune up too.
Good luck!!
Good luck!!
okay rewiring the ecu worked thank you now it fires right up , i gotta question tho , rewiring the ecu will it affect anything , like will my gas go a lot quicker than before ? will it mess anything else up on the car ?
Mine did the exact thing... It was the fuel filter
Aron9000
Performance & Maintenance
12-15-17 05:43 PM
