Check engine light not working??
Have a 1992 Lexus SC400 and it seems to be acting weird, (Thread called "Bucking/surging around 40 MPH") It would seem that the check engine light would turn on, (unless it had Tranny Problems), but regardless of the issues now, and of the past, it has not turned on.The problem I had before, (TPS filthy), among other problems, would have ticked the check engine light on, or would it have not?
Thanks
(PS: I did try turning the key to "ACC" but no go W/ the light.)
Thanks
yes, 93mb is correct, as soon as you start the car, CEL should come on for a quick second then off...if not you def have a blown bulb! (y) switch bulbs as recommended and your good to go! keep us posted!
I looked to see if the bulb worked at "on" position, nothing, no CEL at all so the bulb is burned out.
Is it auto zone's policy that they cannot check for codes if the light isn't on, cuz i wanna see if it will throw code.
What light should I use to replace the CEL, i think the door ajar lamp is a good idea, if it works that is.
and how do i get into the cluster?
Klawler7 (11-15-22)
jtdewall
09-21-08 09:24 AM
