Throwout Bearing Rub Marks on Pressure Plate
Old 06-25-12, 09:53 PM
SC300_704
SC300_704's Avatar
Default Throwout Bearing Rub Marks on Pressure Plate
took my transmission off yesterday b/c it's very worn out due to a few years of abuse and notice deep rub marks on the pressure plate teeth. Clutch, pressure plate and flywheel are only about 3 months old max. don't have a pic right now but you can pretty much imagine how it looks like, abnormal marks around the center of the pressure plate. what could cause the throwout bearing to rub so bad?
Old 06-26-12, 04:45 AM
stockhatch
stockhatch's Avatar
Does the TOB spin freely? The first thing that comes to mind is that the TOB is seizing or failed and is spinning against the PP fingers.
Old 06-26-12, 08:47 PM
SC300_704
SC300_704's Avatar
pics are up
Old 06-27-12, 05:02 AM
stockhatch
stockhatch's Avatar
That does not really look abnormal to me. Its tough to tell from the pics, but it looks like light wear marks and not gouges. You will have some wear normally just from the contact.
Old 06-27-12, 06:33 AM
SC300_704
SC300_704's Avatar
^^ ok that's good to hear. i'll compare it to my old Spec pressure plate when i have time.
Old 06-27-12, 06:54 AM
Tabaka
Tabaka's Avatar
What happens when you hear your throw out bearing chirping non stop until you press in the clutch? Is the throw out bearing rubbing on the pressure plate? I had my clutch replaced in February and it's super annoying to drive through traffic and hear a grasshopper in your transmission.
Old 06-27-12, 01:15 PM
chingpo05
chingpo05's Avatar
its normal signs of wear unless there is noise with your coming from your tob. thats the area where the tob meets to pp to release your clutch. i wouldnt be to worried about it and make sure you dont rest your foot onthe clutch pedal when not being used. lots of customers tend to do this i explain to them they need to depress the clutch completely and take their foot off the pedal.
Old 06-27-12, 03:55 PM
StiCk3
StiCk3's Avatar
same marks on my past 3 clutches, normal wear. i wouldn't worry about it unless you have noise or engagment issues
Old 06-30-12, 08:27 PM
SC300_704
SC300_704's Avatar
was just curious, before i took off the transmission it was hard to get into gears unless i force it in. at first i thought it was the clutch slave, replaced that but no help. thought it might be the pressure plate that failed next but it looks fine when i took it off. whole clutch kit and flywheel is only about 3-4 months old. so last thing i would guess is the transmission itself. i took the transmission cases off and all the gears looks fine, maybe it's the thrust washer or something that i'm missing? btw this didn't happened until i used launch control w/ sticky tires at the track .....
Old 07-01-12, 12:03 PM
SC300_704
SC300_704's Avatar
ok i think i just found out what the culprit is...
this rivet has completely broken off on one of the straps
how it supposed to look like
gap on the big rivet
no gap
are pressure plate straps and rivets replaceable or fixable??
suprasoup
04-04-18 01:31 PM
TheAzn
SC400 / 300 Classifieds
06-24-15 07:00 PM
Ben4991
08-08-13 03:27 PM
hmhatch
07-08-13 07:01 AM
Quick Reply: Throwout Bearing Rub Marks on Pressure Plate
