Boost logic 2jzge Trans on 1jzgte
Hey guys I have a friend selling a 2jzge boost logic Trans for a good price. I think my Trans may be on its way out. Will this mate? And what about the electrical connections?
however im running a aristo A340LE right now. or thats supposedly what im running.
Thanks
Thanks
the BL 2jzge trans will bolt up, there will probably be a couple things different though. The main thing being the big main plug for the gear/pattern selector. The wiring should be the same but the plugs will be different, you might be able to depin the connectors and swap them. You also might have to change the line pressure control cable because the throttle bodies are in different locations, the GE's being the shorter of the two.
unless you have an aristo ecu, or someone has swapped the valve body from a GE transmission into the aristo trans you cannot run the aristo trans
Interesting. It's a modified transmission (increased line pressure and shimmed) but I think it's killing itself. I also have this bucking issue which I think is the Trans trying to shift sometimes. Idk I'm going ahead with it and just going to run full line pressure by Tying the cable into a knot at the end. The plug im sure will e different but I'll just have to find a pin out and go from there.
Thanks!
Thanks!
spoolinmk4
IS - 1st Gen (2001-2005)
07-08-14 05:09 PM
xspsi6
Performance & Maintenance
07-19-12 09:56 PM
