O/D light flashing...code 61
Old 07-02-12, 09:03 PM
durps
durps's Avatar
Default O/D light flashing...code 61
Hey guys, my o/d light is flashing meaning something is going on with the tranny. Its code 61 which means number 2 speed sensor malfunction.
My speedometer is working and is accurate.
My tranny is a bit rough and wonky so would a bad #2 speed sensor cause any thing to be rough?
Mainly happens when I rip it a bit, but does come on from time to time when casually driving.
Thanks in advance!
Old 07-02-12, 09:37 PM
durps
durps's Avatar
Forgot to mention this is a sc4.
Old 07-03-12, 11:06 AM
durps
durps's Avatar
Help please or a link to the second speed sensor online?
Can only find the first speed sensor for sale.
Old 07-03-12, 11:07 AM
durps
durps's Avatar
What im basically asking is what are the symptoms of a bad second speed sensor.
Old 07-05-12, 04:44 PM
rogers2014
rogers2014's Avatar
hey bud, ok well the o/d will def flash, but this can be to various problems (bad tranny, sticky throttle cable, and yes your right speedsensor) i assume you scanned this car correct? well if you know the code, and it reads speed sensor then thats the problem, you could also have bad shift solenoids but i don't think you need to think about that as it would affect the shifting. If you need anymore help pm me, my friend had a similar problem and it was a stick tb (throttle body cable)
edwinbong
07-14-16 11:00 AM
kevster96k
06-04-14 05:13 PM
JM5879
RX - 1st Gen (1999-2003)
17
10-26-11 08:12 AM
sc250tt
SC- 1st Gen (1992-2000)
05-28-07 06:43 AM
Quick Reply: O/D light flashing...code 61
