sc300 na tt build..Harness question
I am building a2jzge na.. to tt I have a soarer ecu and a 1jz head . What do i do with my harness?? i have been told to buy a soarer harness which would need to be moded or use my stock harness and have it moded. I already talked to tweak and a couple others.. A new custom harness is $1200 and a stock soarer harness is going for 400 plus 400 to have it moded.. Any help will be greatly appreciated.. I want to get boosted ASAP!!!!
if you have a soarer ecu, you'll be in for quite a bit of work to make your ge harness work on that ecu. You'll have to run cam/crank sensors, coils/igniter circuits, MAP and IAT, change injection to batch from sequential, repin tps, prob a couple other things, then change all the ecu plugs and pins. An aristo/supra ecu would be easier.
Or just find any 1jz harness, and make it co-exist with your ge harness. Prob the easiest route. Does not have to be a soarer harness. Your ge harness is already pinned for your car.
I'm probably about to put the 2j harness and ecu back in my gf's car since its a little less aggressive than the 1j ecu, and her car has a holset. Hit me up if you want the 1j harness that's running it now. It's a 92
a guy suggested i run a megasquirt standalone and do a patch harness stock ecu with a map 2,, Are you familiar with this kind of setup? they want 400 for labor plus harness 2jzz30 for 250, or a custom at bay for 799. the 1j ecu will not work with an auto trans.,
Lokz
Performance & Maintenance
12-26-12 08:13 AM
