info please
I have a soarer tt front clip on the way. I trying to find swap info. Any body have links to the general procedures of the swap. My main issue is finding about the wiring differences. This is going into a sc300 5spd. trying to do as much research as possible before it gets here. thanks matt
well for starters, the JDM wiring harness is TOTALLY different than the USDM ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
so plan to pull the entire engine wiring harness; its prolly very easy to use the interior harnesses with the JDM harness; its just a matter of getting the right wires spliced, etc...
here's some info of the 1jz in a JZA70 Supra (MK3 with 1jz, very similar to Soarer)
http://home.austarnet.com.au/petew/K...tech_stuff.htm
SupraDremr
Performance & Maintenance
03-07-13 08:48 PM
