What size tap to use to tap ge oil pan for turbo drain?
Old 07-18-12, 10:34 PM
xspsi6
xspsi6's Avatar
Default What size tap to use to tap ge oil pan for turbo drain?
I got the hole drilled but I forgot what size to tap the bolt holes to so does anybody know off hand?
Old 07-19-12, 02:18 PM
cartmill
cartmill's Avatar
i would drill them to match whichever bolts you decide to use to bolt the flange to the pan.
Old 07-19-12, 02:21 PM
Tabaka
Tabaka's Avatar
Club NA-T has a great thread on this. I'm not sure if I'm allowed to post the link or not, but check out the NA-T General Discussion area and you'll see the top sticky called "All about oil lines..."
I hope that helps.
Old 07-20-12, 10:29 AM
Ali SC3
Ali SC3's Avatar
If you are talking about the holes on the sides, then its either an m8 or m10 tap, i want to say m8 but its been a while. if you have both just see which one slips in better.
Old 08-22-12, 04:40 PM
cbasoco
cbasoco's Avatar
I used a 17/64 bit and an 8mm x 1.25 tap.
Old 08-22-12, 04:51 PM
Vwpride12
Vwpride12's Avatar
An m8x1.25 would be a Lexus bolt with a 12mm head. M6x1.0 would be your regular 10mm flange bolt.
propcop
03-29-16 09:38 PM
lbintab
04-20-14 12:38 PM
broda805
SC- 1st Gen (1992-2000)
01-19-11 08:43 PM
flexspeed
15
08-18-09 07:48 PM
SISMO817
GS - 1st Gen (1993-1997)
03-27-07 02:13 PM
Quick Reply: What size tap to use to tap ge oil pan for turbo drain?
