Using usdm 2jzgte harness on a jdm motor questions .
Old 07-20-12, 05:12 PM
MDSC
MDSC's Avatar
Default Using usdm 2jzgte harness on a jdm motor questions .
Ok guys so I'm buyi cherplex harness out of his car it's a usdm obd1 motor he had dr tweak make him a plug in harness . What do I need to make it work on my aristo motor with aristo ecu. How do I go about converting maf to map . Also he's missing iat and maf plugs , do the jdm plugs off the aristo motor work? If there's anything else you guys can think off let me know.I know I have to switch the injector plugs also
Old 07-20-12, 09:45 PM
99SC42
99SC42's Avatar
add the ait sensor from the jdm, and the map sensor , stock injector connector and don't worry about the maf oh and get the connector to jump the tt injector resistor pack connector since you are gonna be on the jdm 440cc they are already hi imp so you don't need a resistor box s you will need to jump that part.
gl
Old 07-20-12, 09:59 PM
account2x
account2x's Avatar
Why don't you just combine your aristo harness with the sc harness?
Old 07-20-12, 10:09 PM
MDSC
MDSC's Avatar
Because its a lot of work and I hate wiring , plus I have a dead line and me and sherwin are doing some wheeling and dealing trading on the harness
Old 07-20-12, 10:10 PM
MDSC
MDSC's Avatar
gl
Thanks a lot Omar , can you explain more about the connector to jump the injector resistor ?
TURBO819
SC400 / 300 Classifieds
11-26-14 01:41 PM
wanganstyl
171
05-19-13 07:52 AM
StuntKing
16
03-31-11 01:07 PM
dsc300nat
10-11-10 06:17 AM
FUZION
08-08-08 07:09 PM
Quick Reply: Using usdm 2jzgte harness on a jdm motor questions .
