440cc Injectors in a SC300
Old 07-23-12, 12:45 PM
super300
super300's Avatar
Default 440cc Injectors in a SC300
Anyone know exactly how you make Mk3 440cc injectors work in a SC300? I know you need a resistor box, but does anyone know the part number of this box? And you only need one, correct?
Old 07-23-12, 02:10 PM
2jzforlife
2jzforlife's Avatar
Stock sc300 runs 330cc injectors. By upgrading wouldnt you run more rich? Are you na-t?
Old 07-23-12, 02:12 PM
TweakTech
TweakTech's Avatar
Why do you want to run bigger injectors? Unless you're going FI, it's kind of a waste of time and money.
Old 07-23-12, 05:35 PM
super300
super300's Avatar
Thanks for the concern, but if anyone knows how to do this, please help. I know it's been done on the GE's plenty of times but I'm having trouble finding info on it.
Old 07-23-12, 05:49 PM
99SC42
99SC42's Avatar
iirc mk3 uses 440cc or something similar .
Old 07-23-12, 06:17 PM
scviolence
scviolence's Avatar
Solder in some inline resistors or get a resistor pack for the injector easy day.... Upgrade maf or go speed density aka map and iat
Old 07-23-12, 07:56 PM
Vrank
Vrank's Avatar
look on a supra site in the classifieds, or find a calculator online to figure out what resistor you'd need to make this happen. You'll want to wire these into the power side going into the injector. Go to *******.com for any part numbers yuo ever need
Old 07-23-12, 08:01 PM
super300
super300's Avatar
Does anyone know the resistors I would need? That is what I'm here to find out.
Old 07-24-12, 03:08 AM
Vrank
Vrank's Avatar
use multimeter and determine resistance of stock resistors. Use same multimeter to find mk3 resistance. Then use online calculator to determine what you need.
Old 07-24-12, 04:24 AM
Vrank
Vrank's Avatar
Ps: it literally took me 5 minutes to figure this out on google
10ohm, 25w or better (I have 50w personally)
Stop being lazy and looking for handouts. You won't learn anything that way
Old 07-24-12, 05:24 AM
99SC42
99SC42's Avatar
Or maybe just get any Honda v6 resistor box and wire it in. gl
Old 07-24-12, 08:46 AM
Vrank
Vrank's Avatar
Quick comes through with good info as usual. Usually like $7 at a pick and pull. Cheapest route probably.
2JZMKIV1
SC400 / 300 Classifieds
01-07-10 04:58 PM
Blk97SC300
02-04-09 11:32 AM
svtdubs
10-01-06 09:09 PM
Dohc3l
12
11-09-01 06:03 AM
Quick Reply: 440cc Injectors in a SC300
