1jzgte supra swap wiring harness to a sc300
Old 07-28-12, 02:07 PM
jwin
jwin's Avatar
Default 1jzgte supra swap wiring harness to a sc300
After doing some research heard that all you have to do it swap some pins and to extended the harness for it to work in a 97 sc300. Can someone chime in that knows if my research is correct? Also which pins do I need to swap.
Old 07-28-12, 05:12 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Contact Cartmill, account2x, or Dr.tweak, they know what is going on here. Sorry if I left someone out here.
Old 07-28-12, 07:19 PM
Vrank
Vrank's Avatar
Are you sure it's even a supra swap? There's lots of information here about doing this. But judging by this thread, I'd say go with cartmill or account2x. Browsing these forums I have complete confidence they know their stuff. This will make your project snap together. Don't spend your money with tweak. Sure people praise him, but you'll get a better deal other places for same quality work or better.
Old 07-28-12, 09:20 PM
jwin
jwin's Avatar
the engine importer says the engine is a 1jzgte r154 from a supra. Considering its already a rear sump i was planning to get it but i don't want to spend another 4-500 doing the wire harness. Rather just wait for a soarer to pop up instead.
Old 07-28-12, 09:39 PM
DoomLight
DoomLight's Avatar
Wait for a Soarer swap. Supra swap is older, cable Speedo, rear trans cover won't fit stock mount, harness crazy different, water pumps different, too much retooling.
You spend another grand just to make it work.
Old 07-28-12, 09:48 PM
cartmill
cartmill's Avatar
if you don't know what you're doing, see if you can find a soarer swap.
if you have an sc300 it will be almost plug-n-play.
Old 07-29-12, 07:15 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I told you Cartmill would come through..
i wish I understood the wiring like second nature to some of these guys on here, but then that is what my check book is for..
Old 07-29-12, 07:28 AM
Vrank
Vrank's Avatar
Have you ver done anything of this nature before? I seriously recommend finding a factory electrical wiring diagram for your year model car, then spend an evening reading through the section in the beginning on how to use the manual. It will teach you how to identify plugs, pin locations, etc. A multimeter and this book is all you really need if you understand automotive stuff.
Seriously though, with your stock harness and some initiative, a jzx90/jzx100 5spd swap wouldn't be so bad either. It'll come with the extended shifter housing you're looking for, just a little more involved as far as combining the two harnesses. And you'd have to drill/tap your stock oil pan for the return flange, then swap pans and locate a factory supra/soarer return flange for the twins. A little more work, but soarer swaps are becoming rare these days. I'd prefer a choice between 5 x chassis front sump swaps over one soarer swap. But that's just me. Whatever you do, take your time to learn what you're getting into. There's lots of good info here and other places. Good luck.
Old 07-29-12, 07:33 AM
Vrank
Vrank's Avatar
Also, do you have any pics of the actual engine set you were talking to the importer about? Because even though they are in the business, they can be completely retarded and call it a supra swap when it is a soarer swap just because it's rear sump. Not uncommon. A pic of the ecu , harness plugs, and engine would be enough to tell us. Seriously, importers can be pretty stupid. They may have exactly what you're looking for without realizing it.
Old 07-29-12, 05:44 PM
jwin
jwin's Avatar
I have done a few engine swaps but none that I had to do extensive wiring. I fix airplanes for United Airlines for a living so I can read blueprints and wiring diagrams. I just don't know exactly what is different between supra and soarer engine. I know the supra has a mechanical speedo but they make an adapater for that from marlin crawler so I believe i can just install that to make it work. I can't find the wiring diagrams for my 97 sc300 or do I have enough wiring diagram for a JDM 1jzgte for supra.
Swap from EBAY
http://www.ebay.com/itm/Toyota-Supra...sories&vxp=mtr
Old 07-29-12, 05:45 PM
jwin
jwin's Avatar
I can't seem to find a soarer swap 5 speed. Should I get vvti or non vvti in a 97 sc300. Im thinking non vvti because my current engine doesn't have vvti
Old 07-30-12, 06:00 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
ever thought about building your current motor? when its all said and done, it will be more capable and you will know exactly what you have, not trying to rely on some importers word that the motor is good...
then there is no wiring problem at all...
Old 07-30-12, 11:56 AM
jwin
jwin's Avatar
My current motor has 215k on it and I want the r154 tranny. It's cheaper to buy a whole swap then to get a r154 by itself considering you pay 1200-1800 for a r154 and 2200 for a 1jz r154 swap.
Old 07-30-12, 01:30 PM
DoomLight
DoomLight's Avatar
Get it with swap.
AceVL
04-12-17 08:17 AM
bigz
06-26-12 08:55 PM
na4now
09-02-07 04:07 AM
PlatSilvSc
10-18-06 04:17 PM
Quick Reply: 1jzgte supra swap wiring harness to a sc300
