2jzgte swap...wont crank
#32
That's not an ECU thing. You can start a car without STA, or NSW at the ECU. We do it will all of our s-chassis, and RX7 harnesses. If the car was originally manual, and the harness was set up for an automatic, there is an STA wire missing on the interior body plugs that needs added.
#34
My car is originally a 5 spd with the stock 5 spd harness. I put the aristo ecu on it and had previously jumpered my clutch start switch, and it started right up and drives good. Don't know if jumpering the clutch switch helps but try that on a original manual car. For an auto harness on a manual car I think people just ground that pin at the ecu when the wiring doesn't exist.
#35
Spent the hole day working on my car and got it to start, I was missing the igniter cable from the Ik1 orange body plug pin 8 black cable that goes to the igniter and got spark to the coils and fuel to the engine.
Thanks for the help guys.
wanganstyl
Performance & Maintenance
171
05-19-13 08:52 AM
