na-t GTE ecu project wont boost past 4k
Old 08-24-12, 08:02 PM
  #31
Vrank
Vrank's Avatar
congrats on finding the problem, little stuff like crappy connectors can really make you wanna pull your hair out.
I like this thread because tweak tech exposes his self for the fraud he is, kind of like in a lot of his other ones. It's apparent he just pulls stuff out of his *** like changing plugs to a colder range to offset severe overfueling issues, 17 psi boost cut when the 2jz map is the same basically as a 1j (screw what google and dumb****s say it's true otherwise if it was scaled different you couldn't correctly run a 1j on 2j ecu and vise versa) or asking what vvti engine he got the coils from since all jz vvti coils are the same. oh and the fact that he took the time to make his first post in this thread a decently long one after apparently not reading the OP. any of you guys considering spending money with this guy should smack yourself and find one of the reputable harness guys on this site.
1a1mk4
04-06-18 10:27 AM
Sabersupra
03-16-17 08:13 PM
shajbot
SC400 / 300 Classifieds
06-24-16 01:29 PM
dubseven
04-09-15 10:47 AM
2jzforlife
10-03-12 09:28 AM
Quick Reply: na-t GTE ecu project wont boost past 4k
