Can old o2 sensors cause bad mpg?
Old 08-14-12, 09:49 PM
durps
durps's Avatar
Default Can old o2 sensors cause bad mpg?
Ok, I know my o2 sensors aren't bad or else a check engine light would come on but I have a 94 SC4 with original o2 sensors and I'm getting baddd mpg. Almost as bad as my Ford Expedition.
I did a tune up and barely saw an increase in mpg, so can old sensors just be dirty and casuing bad air/fuel mixture?
Old 08-15-12, 05:21 AM
Flygfsh
Flygfsh's Avatar
Yes! I recently changed mine and MPG jumped from about 19mpg to 22.38mpg. Purchased thru RockAuto on sale for I think $44 each.
Old 08-15-12, 08:11 AM
durps
durps's Avatar
Awesomeee. Thanks for the heads up. Will be ordering some soon.
Old 08-15-12, 08:40 AM
SFrymyah
SFrymyah's Avatar
absolutely! Be sure to replace them as a set. If the ECU sees one responding faster than the other, it will likely trigger a check engine light. If it doesn't it will assume the fuel mixture is off and compensate for it, decreasing the life of your new sensor.
Old 08-16-12, 03:16 PM
over40driv
over40driv's Avatar
Went to Rockauto, prices all over the board, AWSCI for $35.00 Denso and Delco for twice that. I thought my 93 SC400 was OBD1, they say it has 2 upstream and 2 down stream?
Old 10-25-12, 11:53 AM
jpvarghese
jpvarghese's Avatar
How many O2 sensors are there for the VVT-i 2jz cars?
Old 11-02-12, 02:47 PM
jpvarghese
jpvarghese's Avatar
Anyone know?
Old 11-02-12, 03:12 PM
Ali SC3
Ali SC3's Avatar
you never said your mileage on the originals. the non heated type found on non-cali odb1 (majority of SC's) are supposed to be replaced every 50k miles for optimal performance and mpg and emissions.
heated type found on the later models and cali models should be replaced every 80-100k miles.
every model is a little different, stick a flashlight down there and take a look.
the 2jzge's with non heated o2's have 2 on the manifold for sure.
I think the vvti's have the same 2 on the manifold and one after the cat, but im not 100% on that.
sc400 no idea, really its best to actually go look at your car, you never know if someone has swapped something around on you, which is becoming more and more likely these days.
Old 11-02-12, 04:10 PM
StiCk3
StiCk3's Avatar
on the VVT-i ones should be 2 before the cats, one for the front 3 cyl., the other for the back 3. also one after the cat. Just need to replace the front 2 if you want to see improved gas mileage, the one after the cat is there just to make sure the cats are working.
for the 1UZ, should be 2 upstream (one for each bank of cylinders) and 2 downstream. Again, for better mpg get the 2 upstream ones.
Old 11-03-12, 08:59 AM
jpvarghese
jpvarghese's Avatar
Thanks for the responses. I should have been more clear. '98-'00 SC300 w/ VVT-i. I have approx. 185k miles. I think the last time it was changed was at 60k miles.
Old 11-03-12, 09:36 AM
Ali SC3
Ali SC3's Avatar
heated are recommended every 100,000 miles. they last twice as long as the non heated variety.
as Stick3 pointed out, you want to change the front ones. only need to replace the rears if you pick up a code for them.
Old 03-25-13, 09:07 AM
Biddles
Biddles's Avatar
Thanks for the 1UZ tip. I got CEL 37 for 02 Sensors on my 92 SC 400 and I'm unsure which ones to replace. Since my MPG is around 13(horrible I know) would there be anything wrong with buying all four at once? I know it's expensive, but MPG is important to me. I mean over time these things wear out correct? Should I just get the two Upstream ones for now? I'm going to order from Rock Auto in about an hour along with a Power Steering Pump/Filter. I rather make one big order and fix everything at once.
Old 03-25-13, 12:48 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
You got them 44 bucks each? I had to pay over a hundred bucks each to get mine. Is this a case of stupid Auto Zone, or stupid me???
Rock-a-Lex
09-21-14 11:48 PM
avalon42
19
01-31-10 09:50 PM
wifeses300
02-07-07 10:42 PM
Quick Reply: Can old o2 sensors cause bad mpg?
